SolubleHamster opened this issue on Apr 27, 2003 ยท 1 posts
SolubleHamster posted Sun, 27 April 2003 at 11:29 PM
Since getting P5 aaaaages ago I've had zero problems with it up til now.
For some reason P5 is now throwing up 'fake' Hierarchy editor, Joint editor and Walk designer dialog boxes at a random time interval every time I use P5 for 5 mins or more.
These dialog boxes are unclickable, and uncloseable.
The only way to get rid of the hierarchy and joint editor dialogs are to click window-heirarchy editor/joint editor to call up the real ones and then close them.
If I try the same for Walk designer, P5 stops responding.
I could work around this by never using walk designer, however once these dialogs pop up, the Document window stops refreshing.
I recently bought a Matrox Parhelia gfx card and am using 3 monitors: desktop res 3072x768 32bit @ 60hz, so I'm guessing P5 has 'issues' with multi-monitor displays.
I so hope I dont have to revert to 1 monitor every time I want to use P5 as I use it in conjunction with Lightwave which absolutely ROCKS with 3 monitors.
Looking for anybody's 2c please!
Soluble Hamster
The one, the only, dissolvable rodent.
