dghost opened this issue on Apr 29, 2003 ยท 7 posts
dghost posted Tue, 29 April 2003 at 11:55 AM
How do you create a brush set in Photoshop 7? I can't seem to find a tutorial online...
Thanks!
Damien
yomah posted Tue, 29 April 2003 at 3:24 PM
Good afternoon Damien,
If you would like to make brushes start with a white background and make some marks, or scratches or even type in some text. You should adjust the contrast higher so it is blacker but this is not critical.
When you are done, select the image or the part you wish to make into a brush, from the brushes' palette choose 'define brush'
You are all set. You now have your first custom brush.
Yo
dghost posted Tue, 29 April 2003 at 8:57 PM
Thanks! But, I meant a set. There's a way to organize the brushes you create into like libraries or sets...
D
retrocity posted Tue, 29 April 2003 at 10:27 PM
What you do is delete all the brushes you DON'T WANT on your set from the brush palette and then save/rename the brush set. Don't worry, you aren't really deleting the brushes, just removing them from activly being avalable in the palette. Select RESET BRUSHES to return to the default set.
retrocity
karosnikov posted Thu, 01 May 2003 at 2:17 PM
BTW is there a key boad short cut to increase or decrase the brush side for mouse pple?
dreamer101 posted Thu, 01 May 2003 at 4:40 PM
[ decreases brush size
] increases brush size
karosnikov posted Sun, 04 May 2003 at 2:42 AM
yeah I tried every other key -but that one- thx slaps own forehead
