Subject: Lights Problem
meekinsdh opened this issue on May 02, 2003 ยท 5 posts
meekinsdh posted Fri, 02 May 2003 at 7:52 PM
I've noticed in some light set that I've downloaded several of the lights are actually "black". These sets seem to cause rendering problems of some type. If I delete the black lights the problem seems to go away. Anyone else out there having this problem and know of a solution other than deleting the black lights? Thanks, Dennis
lelionx posted Sat, 03 May 2003 at 10:40 AM
what are the names of the sets?
meekinsdh posted Sat, 03 May 2003 at 4:20 PM
They seem to be all the sets I downloaded from RDNA.
lelionx posted Sun, 04 May 2003 at 2:12 AM
sounds like they maybe some sort of global lighting.in global light sets the lights that look black are not actually black.they can be any color but they look black because the intensity is turned down very low.most global sets have more than 20 lights which takes up ram.poser is a real ram hog and the more objects you have in a scene,including lights,the more ram is taken up.it also sounds like maybe you're importing the lights as pz3 files.this has never worked for me.any time i import a pz3 the lights come out all screwed up and have to be deleted.the only way i've been able to get a pz3 light set to work is to close poser and double click on the file.this will open poser with the light set working properly.it can then be saved in the library.the down side to this is it always screws up the way i have the interface set up.i always have to reset everything and resave to prefered state.also some light sets point to a character.if there are only props and no characters in your scene the lights may not work properly.another thing that can screw things up is if you don't have all the current patches for the version of poser you're running.4,pp and 5 all have bugs and need patches to work properly.
meekinsdh posted Sun, 04 May 2003 at 6:58 AM
Thanks for your help, that sounds right. In fact I just installed the Poser 5 update and things seem to be working better now. Thanks again for taking the time to help me out. Dennis
