Kagato98 opened this issue on May 04, 2003 ยท 7 posts
Kagato98 posted Sun, 04 May 2003 at 5:37 PM
tasquah posted Sun, 04 May 2003 at 5:51 PM
you can do it in uv mapper . Pict the material you want then hide the rest using this key " [ " then save your template and make sure to check the box " Exclude hidden facets " your also going to have to export your model as well with the new UV mapping in it .
Poppi posted Sun, 04 May 2003 at 6:28 PM
there is a most wonderful tute in the rhino forum, by GROINGRINDER....just search for uvmapping, and, you can't miss it.
maclean posted Sun, 04 May 2003 at 6:40 PM
Attached Link: http://uvmapper.com/phpBB2/index.php
1. Press ctrl-m (select by material) 2. Press ' (apostrophe) to hide everything except your selection. 3. Press ctrl-t to save the template and check 'exclude hidden facets' 4. Press ] to show all, and carry on. If you get stuck, go to steve cox's uv mapper forum for tips, tutorials and answers directly from the man. macmaclean posted Sun, 04 May 2003 at 6:42 PM
Incidentally, with a model like that, you should really use different mapping for the various parts. I'd go mainly with box mapping, but the pipe will need cylindrical. It doesn't look too easy. A bent pipe is a nightmare. Try asking steve on that one. mac
Kagato98 posted Sun, 04 May 2003 at 7:03 PM
Thanks for all the help - I think I'll probally be able to take it from here. And about that bent pipe - it probally will be a challenge, but I'm not all that worried about it. I'll get by it somehow - and if worse comes to worse, I'll just use a procedural texture in poser for that.
Jaager posted Sun, 04 May 2003 at 7:18 PM
The part I do not see suggested - when you isolate a material - hiding everything else - you can give the whole map area to that material. Efficient in texture size needed, a pain to apply.
