Forum: Bryce
Subject: Help or suggestions please!
TheBryster opened this issue on May 08, 2003 ยท 22 posts
TheBryster posted Thu, 08 May 2003 at 10:27 AM
I'm trying to create a realistic splash here. At the top of the big 'wave' (marked with an arrow) I want to place small droplets of coffee that look as if they're just leaving the top edge of the wave. They should actually just touching the wave but the edge should be 'scalloped' at the same time all the way round. Has anyone got any suggestions? Bearing in mind that simply neg-boolean (spelling) will leave shape edges and that is not what I'm looking for here. Thanks!
Dash101 posted Thu, 08 May 2003 at 11:07 AM
hmm.. Perhaps metaballs with motion blur in post? ugh.. Best I can do at the moment.
Jausse posted Thu, 08 May 2003 at 11:54 AM
I'd go for metaballs all the way. Josselin
Rayraz posted Thu, 08 May 2003 at 12:07 PM
The ring should gradually blend to drops
(_/)
bikermouse posted Thu, 08 May 2003 at 12:09 PM
you could use Parametric Terrain Editor(mentione on bryce forum once or twice in the past complete with links - search in Bryce Forum under parametric should get it) to make a wave effect on the water using a terrain for your water. As for the splash, metaballs sounds like the best bet.
Innovator posted Thu, 08 May 2003 at 1:41 PM
Attached Link: http://www.petersharpe.com/Tutorial32.htm
Try this peter sharpe tutorial. I have tried it and it works great.
TheBryster posted Thu, 08 May 2003 at 2:45 PM
Thanks, guys! Innovator's tut looks good, but I'm trying to get a uniform effect, not a chaotic splash as in the tut.
TheBryster posted Thu, 08 May 2003 at 2:46 PM
Looks like the E-bots aren't working again
Rayraz posted Thu, 08 May 2003 at 3:11 PM
Sorry for my short reaction. I had very little time to read and asnwer this thread. There used to be a water-splash object in the freestuff section. I can't seem to find it though. Anyway, the big high ring you made should usually be lower and have 'spikes' where the droplets splash up. Then the actual little droplets can just be spheres. I'll see if I have the freebee somewhere on my Bryce-station. If I find it I'll post a DEM and a wireframe view.
(_/)
madmax_br5 posted Thu, 08 May 2003 at 3:13 PM
create a sqaure array of small metaballs about 25 per side (600 total) Move the array over the terrain. Make sure it is ungrouped and all the balls are selected. Then go to the edit pallette, pull down the arrow under the align tools and select "snap to land." That will drop the metaballs onto the curve of the terrain.
TheBryster posted Thu, 08 May 2003 at 4:52 PM
Raraz: That's EXACTLY what I want. But How do I get it? The water-slash object only works if it's bottom edge is in contact with an infinate plane. Madmax:???? Sorry, I think you're gonna have to draw me a map....
tjohn posted Thu, 08 May 2003 at 4:58 PM
Don't know if this will help, but this is a splash I made in about an hour with metaballs and one negative and one positive torus booleaned together for the sides of the splash. You can probably see how it's made by looking at the wireframe.
TheBryster posted Thu, 08 May 2003 at 5:03 PM
TJohn: MY HERO!!!! OK, I already have the 'sides of the splash' just the same as you but the curve is not so defined. Question: Have the metaballs blended to give a kind of scalloped edge to the top edge of the wave/tori? & can you e-mail the wire to me or is it too big? Either way you seem to have cracked it...I guess I'll have to go and try this myself. MANY MANY MANY Thanks.
tjohn posted Thu, 08 May 2003 at 5:15 PM
I started with 2 stretched metaballs in close enough proximity to "blend" a little. Then I grouped them (these are the ones in the center) and copied and shrank them down a little. Then I copied the smaller group and copied and positioned the copies in the general circular pattern you see here. Then I ungrouped all the metaball groups and grouped them all together into one big group (this was to add a little randomness through the effect the metaballs have on each other). I've seen your skills at work...I think you can do even better than this on your own. :^) It's nice to be someone's hero now and then.
tjohn posted Thu, 08 May 2003 at 5:20 PM
Oh, and I probably cheated here by using a transparent texture, with the texture you have up top, you may have a problem hiding the lower metaballs. Good luck!
TheBryster posted Thu, 08 May 2003 at 5:22 PM
TJohn: Hugs & a friendly slap on the back!! Thanks! I get the idea...I can do this....!! :-) I have skills?....I'll just go and swell my head in private....LOL Thanks, Mate! Regards The Bryster
bikermouse posted Fri, 09 May 2003 at 7:41 AM
I was trying to remember what they call the pattern a "splash" makes - I'm sure that there is a name for it - I wish I could remember it.
Rayraz posted Fri, 09 May 2003 at 3:25 PM
a ripple?
(_/)
bikermouse posted Fri, 09 May 2003 at 4:51 PM
The crown like effect - I'm sure there's some technical name for it.
tjohn posted Fri, 09 May 2003 at 6:46 PM
Maybe corona? No idea really.
TheBryster posted Fri, 09 May 2003 at 7:39 PM
TJohn: I think I might get a better effect by using a Torus made out of metaballs, which I've done. My problem now is, I think there are keystrokes which allow boolean operations between primitives and metaballs or even pos-metaballs and neg-metaballs, but I don't know what they are? PS: thanks for your help so far.
tjohn posted Fri, 09 May 2003 at 8:22 PM
Sadly, I think that primitives and metaballs ignore each other. I would love to be wrong about this. Maybe in Bryce 6 (Please.)
