cinema opened this issue on Jun 05, 2000 ยท 6 posts
cinema posted Mon, 05 June 2000 at 1:22 PM
I have a problem... It started out of the blue , I have no idea if I did something , or what happened . Whenever I try to open a PZ3 file in Poser4 , I can get all the props , hair , etc .to show up , but not the body .For instance , April by Thorne , will show the hair and all the props , but no April .When I check the properties on the bodyparts , they are all listed and checked as visible , but I can't see anything in the workwindow .It does that to the PZ3 files only .I have reinstalled Poser twice now , but it's the same .Can somebody help ? Please ? Thank you , cinema
kyrin posted Mon, 05 June 2000 at 2:35 PM
WOW! That's not good. My suggestion would be to backup your characters, textures etc. and uninstall the app then reboot and re-install it. Hope it helps...
buck posted Mon, 05 June 2000 at 4:05 PM
Try replacing the figure and see if that works. Keep the props, etc.
cinema posted Mon, 05 June 2000 at 4:56 PM
thanks for all the help , I had a system backup and finally got it to work .Thank you All!
Darth_Logice posted Mon, 05 June 2000 at 8:46 PM
In the future, sometimes Poser 4 makes a rsr for pz3's. Delete it...delete the RSR in Geometries file...either of those should fix it all up. -Darth
3DSprite posted Tue, 06 June 2000 at 12:16 AM
This does happen a lot, so don't let it bother you. Darth is correct with his fix ;-)
