vernonglen opened this issue on May 14, 2003 ยท 4 posts
vernonglen posted Wed, 14 May 2003 at 3:59 PM
I am trying to place a label on a bottle in Carrara 2.0. I am able to create a rectangle containing the label on the glass bottle, but I cannot figure out how to keep the label solid, it comes through as transparent. This is one area that worked a lot more easily in Ray Dream. thanks a bunch in advance. Vernonglen
MarkBremmer posted Wed, 14 May 2003 at 4:21 PM
You need to set a value in the label transparency channel to zero. I suspect it currently is inheriting the transparency of the bottle because it's been left at "none". Mark
Hoofdcommissaris posted Thu, 15 May 2003 at 3:52 AM
Attached Link: http://www.chez.com/litst/eng/tut-label/tut-label.htm
There is a great light shed on this subject by this tutorial by Litst... It helped me a lotvernonglen posted Thu, 15 May 2003 at 10:59 AM
Thank you, your answer was clear and correct. Vernonglen
