Subject: Deleting Morphs from the CR2
kinboat opened this issue on May 16, 2003 ยท 7 posts
kinboat posted Fri, 16 May 2003 at 8:46 PM
I'm trying to delete some morphs from a figure and I can't figure out how (except maybe deleting them line for line from the file which would take forever). I went into the Hierarchy menu and deleted the listings for each morph there but they are still in the CR2 file. Any ideas on a fast and hopefully simple way to do this?
Crescent posted Fri, 16 May 2003 at 10:01 PM
Look for Morph Manager in the Free Stuff - Poser Utility section, IIRC. You can load up a .cr2 file and delete morphs from it.
Little_Dragon posted Sat, 17 May 2003 at 6:36 AM
After deleting the morphs from the Hierarchy menu, did you save the character to the Library, creating a new CR2? The file won't be affected by what is done in Poser unless you save.
maclean posted Sat, 17 May 2003 at 9:43 AM
'deleting the morphs from the Hierarchy menu'
Say what?
I've never heard of such a thing...
mac
Little_Dragon posted Sat, 17 May 2003 at 10:00 AM
It works like this, maclean:
Open the Hierarchy Window.
Enable the "Show All Parameters" option.
Select a morph channel.
Press the Delete key on your keyboard.
Repeat as necessary until your fingers fall off.
Little_Dragon posted Sat, 17 May 2003 at 10:03 AM
maclean posted Sat, 17 May 2003 at 10:38 AM
Sorry, LD. My bad. For some reason, I was thinking of the Joint Editor. Probably because I seem to spend my entire life using it. LOL.
Yes, of course you can use the hier editor, although, as you pointed out, if you don't save, you're wasting your time.
mac</moronic daze>
