hawkstheman opened this issue on May 18, 2003 ยท 3 posts
hawkstheman posted Sun, 18 May 2003 at 7:19 PM
Recently I been getting problems with the poser files I save. When I reload them there are no objects only the ground, and the saved files when I check are less than 500K. I'm using poser 4.0.3.
"Power tends to corrupt, and absolute power corrupts
absolutely" - Lord Acton 1877
"Unlimited power is apt to corrupt the minds of those who
possess it" - William Pitt, the Elder 1770
Huolong posted Sun, 18 May 2003 at 10:04 PM
I assume that you saved files before with no problem. What has changed?
Gordon
lesbentley posted Mon, 19 May 2003 at 7:02 AM
Try a reinstall of Poser, that may fix it, though you will lose your prefered state. I have herd that somtimes the "Poser.RSR" file gets corrupted and that causes problems that a reinstall will fix. If you need to preserve your prefered state try saving a UI Dot, then backing up the .RuntimeDOTS folder, then restore it after the reinstall, I think that should restore most of your prefered state. Don,t forget to install the 0.3 update patch.
