Speedbump opened this issue on May 19, 2003 ยท 6 posts
Speedbump posted Mon, 19 May 2003 at 6:42 PM
Okay folks here it is....Stupid question of the day. I have beat myself up for quite awhile trying to figure out how to render a wireframe figure in poser. I thought it was possible but now I don't know...PLEASE HELP ME, I BEG OF YOU KIND PEOPLE. (Yes that was a scream).
SamTherapy posted Mon, 19 May 2003 at 7:03 PM
Several schoools of thought on this one, and naturally, I think my way is the best... Texture your model with the UV template, and render as normal. If you want to have the bits in between as see through, make a transparency map from the template. You could also make a composite texture by blending a regular skin tex with the UV template in Photoshop, then applying that to your model.
denden posted Mon, 19 May 2003 at 7:09 PM
It's also easy to do it in trueSpace and probably other 3D proggies.
maclean posted Mon, 19 May 2003 at 7:25 PM
Set the document style to wireframe, then go to Menu/File/Export/Image and choose jpeg, psd, whatever. That will give you exactly what's on your screen, lights, magnets, and uncle tom cobbley and all and all... mac
wyrwulf posted Mon, 19 May 2003 at 10:08 PM
Nance posted Mon, 19 May 2003 at 11:00 PM
or, yadda yadda blah blah, etc. (translation: Use huge UV template as trans-map)
