Subject: I'm trying to make a easy movie
Darkness opened this issue on Jun 08, 2000 ยท 4 posts
Darkness posted Thu, 08 June 2000 at 1:56 PM
Hi all, i've created a scene in poser, and now i want to make a "fly-over"-camera movie it's basicly a circulair movie( easy loop) in Bryce it was possible by only drawing a circle and attach the camera to it, but i cannot find how to do it in poser, unless i set the cameraview for each frame
MadRed posted Thu, 08 June 2000 at 3:29 PM
You could try using Make Path, and attaching the camera to the figure.
Nance posted Thu, 08 June 2000 at 3:46 PM
When I tried to let Poser's Loop Interpolation set the last frame, it reversed the rotation following the last keyframe at #23. So, I set frame 30 as the last keyframe for yrot and manually entered the value as 348 (360 minus one-thirtith of 360) frm #1=0 yrot frm #8=90 yrot frm #15=180 yrot frm #23=270 yrot frm #30=348 yrot Looks clean now.
pack posted Thu, 08 June 2000 at 9:19 PM
Use the graph & adjust the Y-Rotate for the camera, or set the first frame=0 degrees last & frame =360 degrees for Y-Rot
