Deal opened this issue on Jun 08, 2000 ยท 3 posts
Deal posted Thu, 08 June 2000 at 9:14 PM
O.K. I'm having trouble with 3d max importing and exporting .obj files. Sooooo if I wanted to make a morph of let's say the head, could I export as a .3ds file, then import it into 3d max. Then after I'm done export as a 3ds. and THEN in Poser import the 3ds. file and THEN export as an obj. .......would that work?? thanks for any help:)
Serpent posted Thu, 08 June 2000 at 9:55 PM
Hello, Probably not, but I'm not sure. Go to the Utilities section on the Poser Free Stuff here and get the habware obj plug-ins. Serpent
LoboUK posted Fri, 09 June 2000 at 4:18 AM
You probably could do it that way, but it is extra work and it might not work properly. As Serpent says, get the habware plugins from the free stuff section and work directly on exported OBJ files. I use the Habware OBJ import/export plugins all the time and they make life soooo much easier. Paul
