draculaz opened this issue on May 22, 2003 ยท 6 posts
draculaz posted Thu, 22 May 2003 at 8:33 AM
pakled posted Thu, 22 May 2003 at 11:17 AM
hmm...been doing something the same recently. I've been (in Wings 3d) taking primitives, extruding all faces slightly, and also playing with the Mirror command (if you don't select a face, it mirrors all of them. Real quick way to make complex buildings..;). The map looks good, maybe just build up buildings of different heights, maybe a gondola or 2, bridge of Sighs,St. Mark's square, Rialto bridge, etc.?..;) You can always bring the focus to a lower altitude to save yourself some work. Depends on where you want to go with it..
Incarnadine posted Thu, 22 May 2003 at 11:19 AM
Interesting effect, if you make several further variants and mix them in it could really rock.
Pass no temptation lightly by, for one never knows when it may pass again!
draculaz posted Thu, 22 May 2003 at 11:32 AM
guys, the onl wip that i'm working on is of the model itself. this is just something i put together in 5 minutes so i could get a realism check on the buildings themselves :)
Roch222 posted Thu, 22 May 2003 at 8:34 PM
I ddont know they seem kinda flat to me, too low. its hard to really check for realism - cuz the texture makes them look sunken roch222
Roch222 posted Thu, 22 May 2003 at 9:14 PM
drac... just curious which max plugin tut. did you use.
