markdc opened this issue on May 24, 2003 ยท 1 posts
markdc posted Sat, 24 May 2003 at 6:04 AM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=19834
Want to make your own clothes for Poser? This video based tutorial takes you through the process of modeling and conforming clothes for Poser figures. What makes this tutorial different from others is that it makes use of video to show you every step in detail. The modeler used for this tutorial is 3dsmax, however any polygon modeler that supports subdivision surfaces (lw, maya, cinema4d, wings, anim8or, etc.) can be used to follow this tutorial (max only commands are avoided). The tutorial is broken up into discrete topics so you can view sections that youre interested in. The tutorial is sold in four downloadable parts as listed below. You can buy all parts on CD at the following link: http://market.renderosity.com/softgo od.ez?ViewSoftgood=16487 Part 1: Lesson 1 Overview What's Covered Required Software CD contents Lesson 2 Basic Modeling Vertices, Polygons, Edges Translate (Move) Scale Rotate Cut/Knife Slice Extrude Bevel Clone Mirror Weld Subdivide Lesson 3 Modeling the Shirt Importing the target figure dummy (3 mins) Creating and mirroring the box (6 mins) Creating the basic shape (15 mins) Creating the sleeves (5 mins) -------------------------------------------------------------------------------- Part 2: Shaping lower/mid (16 mins) Shaping upper (12 mins) Welding (8 mins) -------------------------------------------------------------------------------- Part 3: Adding Trim (17 mins) Material zones (13 mins) Grouping (24 mins) Exporting (3 mins) -------------------------------------------------------------------------------- Part 4: Lesson 4 Conforming w/QuickConform (3 mins) Testing the shirt in Poser (7 mins) Editing Joint Parameters (10 mins) Lesson 5 Basic UV Mapping (6 mins) Lesson 6 Texture Mapping (7 mins) Creating a Mat Pose with Matfile_gui.py (3 mins) Lesson 7 Packaging for Distribution (6 mins) Please email me with any question.
