Strixowl opened this issue on May 25, 2003 ยท 5 posts
Strixowl posted Sun, 25 May 2003 at 4:42 PM
All I really want is a cylinder with a cone on each end. After an hour I finally got the 3pieces to stick/become one. Great but it would only let me move it on the X & Y axis forget Z, no go. Then for the heck of it I went to the Materials editor and assigned materials, then saved to props library and deleted the new prop and tried to load it. It loaded but was invisible. All I want is a NoseSpike type piercing I can put a texture on and scale and move as I need. I was following Geeps tute but it got confusing because what he was doing was more complex. Any insights oh great and knowledgeable ones ??????
tasquah posted Sun, 25 May 2003 at 4:55 PM
its pretty easy if you have uv mapper to make them. Its whips out some pretty nice props. Best way to do it would be to parent the 2 end pieces to the middle cylandar part. If you have a photo of what your trying to make i can whip one up for you.
tasquah posted Sun, 25 May 2003 at 5:20 PM
I opened up poser and tried there basic props and it looks like they all have the origin at the ends of one side. so you probly need to center them some more. Use wire frame display mode and double click the prop and check the show origin box. This opens up 3 new dials to use . The origin Y dial should move it to the center of the clyndar . I would leave the 2 cones origin alone. When it centered move the cones in and parent them then drop it to the floor save it and export / import it back into poser .
maclean posted Sun, 25 May 2003 at 5:37 PM
pakled posted Mon, 26 May 2003 at 11:42 AM
or if you're lazy like me, go to the Modelling forum here and pick up either Wings 3d (www.wings3d.com), or Anim8tor. 3 primitive objects, glom together, and you're dealing..it can be addictive, tho..;)
