BigNick opened this issue on May 26, 2003 ยท 12 posts
BigNick posted Mon, 26 May 2003 at 6:14 AM
So, I followed the instructions given to me the other day, and they worked...however, now that my figure is in Bryce with thier textures, they aren't in the pose that I put them in...they are in that goofy crucifix pose they start out with, and thier props are all over the place. Could someone please give me some Idea as to what I am doing wrong...
One more thing, is there a way to bring an animation in Poser to Bryce?
Thx
Nick
Spit posted Mon, 26 May 2003 at 6:30 AM
Sounds like you imported the .obj from geometries instead of the .obj you exported?
BigNick posted Mon, 26 May 2003 at 6:32 AM
I am not really sure what you mean? lafs Shows what I know...
Spit posted Mon, 26 May 2003 at 6:53 AM
Did you do File:Export...wavefront obj? Remember where the file went and use that one to import into Bryce.
BigNick posted Mon, 26 May 2003 at 6:54 AM
That's what I am doing....and it's still screwed up..
Spit posted Mon, 26 May 2003 at 7:02 AM
If your figure is posed in Poser before you export, then it will come in fine to Bryce with its pose. Do it again and put it in a separate folder all by itself. Don't ungroup in Bryce. Use CTRL-click to select pieces if you want to fiddle with them in the Material Lab.
Bladesmith posted Mon, 26 May 2003 at 8:21 AM
If you're using propack is is possible you selected the option 'as morph target' in the export options....don't do it... If that's not the case, I have seen it before, and have no idea why it does that occasionally.
WaxTextures posted Mon, 26 May 2003 at 9:33 AM
BigNick - Do a web search for all of the words "Poser Bryce Import". You should find more than a few decent tutorials. Some are generic and some are Millennium character-specific. Once you have the 'recipe' down, it's not so angst-making. -Nancy.
Spit posted Mon, 26 May 2003 at 11:18 AM
Yeah, take the defaults on everything! on export (especially that last dialog..you don't need all the steenking body parts)
pakled posted Mon, 26 May 2003 at 11:39 AM
If you have Poser III, and don't have the ability to keep your texturing, checking that last box may make it easier to texture (a poor sod who had to..;) each part..;)
BigNick posted Mon, 26 May 2003 at 11:43 AM
Actually, I have poser5....and nothing seems to work...
EricofSD posted Mon, 26 May 2003 at 4:55 PM
Attached Link: http://www.annsartgallery.com/links.html
Bottom left of my links page has a few links to Poser/Bryce tuts. Maybe you alreay have those.
