joeposer opened this issue on May 26, 2003 ยท 9 posts
joeposer posted Mon, 26 May 2003 at 11:57 PM
When I import a poser figure, as an obj file, everthing looks good, But the eye brows and eye lashes appear odd, not like the real thing. The Trans files don't load up.
I hope you know what I'm talking about. How do I fix that?
Hyria posted Tue, 27 May 2003 at 12:44 AM
actually they do, as with the vicki character she has 2 sets of eyeballs, one to be set to a glass mat and the other to be left alone. go to the little arrow to show meshes and find the 2 eyelash meshes. they will start with Head: then folowed by a number. just choose each one you find until you get to the one that is for the thicker lashes then choose delete. this will leave you the additional lashes you put on your figure. there are also 2 sets of eyebrows (uppder ones and lower ones) hope that helps.
Insanity is a waking state...Darkness is a being...Want To Play.........heheheheh
joeposer posted Tue, 27 May 2003 at 1:12 AM
Ok, I did that, and I got the eye brows to work, But there was only one mesh for the eyelashes. I deleted that and now there are no lashes what so ever. I still want the lashes, just normal looking ones.
EricofSD posted Tue, 27 May 2003 at 1:17 AM
eyelashes are transmaps just like hair. You need to select the eyelash mesh and set the texture to the transmap settings that you would do for the hair. Does this make sense?
Flak posted Tue, 27 May 2003 at 1:28 AM
Attached Link: http://uqconnect.net/wasteland/tut/eyelash.html
There's a really quick tut I wrote up on it for a friend of mine who was having that same problem a while ago. That was for posette lashes I think, so use at your own risk ;)Dreams are just nightmares on prozac...
Digital
WasteLanD
joeposer posted Tue, 27 May 2003 at 1:38 AM
No it doesn't. I'm sorry, Im brand new to bryce 5. I loaded up a figure without any hair. Just the plain bald figure victoria 2. I don't how to set the texture to the transmap settings. I've dinked around with it but can't figure it out.
joeposer posted Tue, 27 May 2003 at 1:51 AM
It worked. Yeah! All Right baby! The insructions on the weblink worked. Thank you. Thankyou all.
Flak posted Tue, 27 May 2003 at 2:01 AM
Just glad someone found it useful :)
Digital
WasteLanD
Incarnadine posted Tue, 27 May 2003 at 11:31 AM
Flak, an exellent little tut on the issue. Well summarized.
Pass no temptation lightly by, for one never knows when it may pass again!
