denden opened this issue on May 27, 2003 ยท 3 posts
denden posted Tue, 27 May 2003 at 6:17 PM
I can't figure out how to size material to map to Vic3. There isn't any info that I can find. Help, please. I'm trying to map a circuit board pattern to Vic3's face but the pattern is much to large. In trueSpace you select the number of times you wrap the texture. However, trueSpace doesn't like Vic3 and turns any texture into a solid color. Thanks for any suggestions.
ronstuff posted Tue, 27 May 2003 at 6:29 PM
Attached Link: http://www.uvmapper.com
If you are using Poser 5 you can do it by altering the scale of the material node, but if you are using Poser 4, you will have to create a new mesh object with revised UV mapping. You can use Steve Cox's UVMapper (see link) to do that, but you can't do it inside Poser 4.denden posted Wed, 28 May 2003 at 11:46 AM
Thanks, ronstuff...I'm still with Poser 4 so I'll follow your suggestion and play with UVMapper. Thanks, again
