Subject: Water Refraction pattern Dolphin texture
Mesh_Magick opened this issue on May 28, 2003 ยท 27 posts
Mesh_Magick posted Wed, 28 May 2003 at 2:26 AM
This is the effect of the texture on the poser 4 dolphin. enjoy. I hope this gives a few people some ideas so a better one can be made then this one, im not to happy the way this one turned out. Maybe someone can make a reflection map that can do the same thing?
narcissus posted Wed, 28 May 2003 at 2:45 AM
Lovely effect,haven't thought of it,very clever idea! Thanks for the texture!
A_ posted Wed, 28 May 2003 at 4:59 AM
Thank you, it's beautiful! Very clever indeed. :)
begga posted Wed, 28 May 2003 at 5:03 AM
thanks a lot, always wondering how that could be done :BH
Mesh_Magick posted Wed, 28 May 2003 at 5:05 AM
This would great on scuba tanks diving gear like the cat suits for diving suits and even on nude textures of poser figures for that skiny dipping effect. water monsters, whales, fish. the bottom of ponds and pools, I think this effect is worthy of more exploration, Iv only seen a few people exploring it.
Mesh_Magick posted Wed, 28 May 2003 at 5:08 AM
in case someone want to use the texture I used to make this effect,here it is.
Mesh_Magick posted Wed, 28 May 2003 at 5:13 AM
2
SAMS3D posted Wed, 28 May 2003 at 7:31 AM
This really stunning...thank you..Sharen
Mesh_Magick posted Wed, 28 May 2003 at 7:32 AM
thanks glad you like it:)
Mesh_Magick posted Wed, 28 May 2003 at 7:34 AM
Ill make a few more of these because I don't want the water refraction to look the same on each dolphin.
Mesh_Magick posted Wed, 28 May 2003 at 7:38 AM
If you want a good effect with this texture you must use a spot light in poser aimed at the back dorsal fin from behind it, this will allow the water patterns to pick up the light in such a way that they look like light, Also in paint shop pro you might want to add some contrast to the image to blur it out some so they look like they are really under water.
Momcat posted Wed, 28 May 2003 at 7:40 AM
Really great effect >^_^
TrekkieGrrrl posted Wed, 28 May 2003 at 7:54 AM
This is really amazing! Thanks for the thip and the textures :o)
tasquah posted Wed, 28 May 2003 at 9:02 AM
The idea is sound and one i wouldnt have thought of right off the get go, thanks for shareing the idea with us Mesh_Magick. You might want to delete that extra dark blue line in the map ( right side ) it has pushed the texture off a smidge .
Blazerwiccan posted Wed, 28 May 2003 at 9:32 AM
Thank you :) Great idea.
Mesh_Magick posted Wed, 28 May 2003 at 9:38 AM
lots of dolphins
Mesh_Magick posted Wed, 28 May 2003 at 9:41 AM
hmm I think im going to really need to make other textures, at least 6 to get away with useing the same textures.
Lawndart posted Wed, 28 May 2003 at 2:28 PM
Attached Link: http://www.3-AXIS.com
WOW! This is really awsome! Hey... Here is an additional idea. If you have Poser 5 you can use the texture as a light gel. The light would take on the color and pattern of the texture map and give you caustics. You may even be able to get volumetric lighting to work through the gel. I'm sure that the effect would look a bit differant though. The last image is stunning. I love dolphins. All the best, Joe www.3-AXIS.com
Mesh_Magick posted Wed, 28 May 2003 at 6:18 PM
I promised a better texture here it is
Mesh_Magick posted Wed, 28 May 2003 at 6:19 PM
I think it works better too
try them both
igohigh posted Wed, 28 May 2003 at 8:18 PM
Attached Link: http://www.lysator.liu.se/~kand/caustics/
Awsome texture idea! Here's a link I found for a free Caustics Texture Generator in one of the PhotoShop forums. Maybe it will be helpful in future textures (Daz SeaDragon ;): http://www.lysator.liu.se/~kand/caustics/
Mesh_Magick posted Wed, 28 May 2003 at 8:45 PM
both dolphins have different maps nnow
ardvarc37 posted Thu, 29 May 2003 at 2:10 AM
_>
who3d posted Thu, 29 May 2003 at 4:22 PM
I'd have thought either applying the texture to a light (Poser 5 only?) or as a transmap on a plane between a light and the subject/s would provide a similar but more variable result without "seams"??
Mesh_Magick posted Thu, 29 May 2003 at 7:12 PM
getting better
Lyrra posted Sat, 31 May 2003 at 9:39 PM
the textures have been removed from this thread as they contain copyrighted material that cannot be distributed. Lyrra (moderator)
