Hdrider opened this issue on May 29, 2003 ยท 4 posts
Hdrider posted Thu, 29 May 2003 at 5:39 PM
Hello, Has anyone else run across this problem. When I try to access the Poser4 librarys in Poser5, it locks up and I have to keyboard exit the program. Anyone have a clue as to what is causing this? Thanks, hdrider
No good deed goes unpunished ...
lalverson posted Thu, 29 May 2003 at 6:01 PM
I found that you have to let the system/poser run a bit to finally take the P4 runtime as a valid library. If you rush it, or touch any key it will freeze. I pointed mine to it and let it chew on that, it only took 20 minutes to change the runtimes. then it worked.
Lawndart posted Fri, 30 May 2003 at 12:43 AM
Attached Link: http://www.3-AXIS.com
Mine was the same as lalverson. Took a while. Didn't take 20 minutes but it did take a good 5 min. I think it is fine once you let it rip through the runtime. Cheers, Joe www.3-AXIS.comHdrider posted Sat, 31 May 2003 at 6:58 AM
Hello, Okay, I tried your suggestion and left the computer alone for an hour and nothing happened. It still was locked up. Any other ideas? Later,
