tradivoro opened this issue on May 29, 2003 ยท 12 posts
tradivoro posted Thu, 29 May 2003 at 10:59 PM
tradivoro posted Thu, 29 May 2003 at 11:19 PM
Now, of course, after I put up the post, the reflections in the pot decided to go away and be normal.. So that part is not a problem... But it still doesn't look like stainless steel... :)
Djeser posted Thu, 29 May 2003 at 11:42 PM
Could you put up a photo of stainless steel to compare it to?
tradivoro posted Fri, 30 May 2003 at 9:11 AM
tradivoro posted Fri, 30 May 2003 at 9:14 AM
Just so you know, I've changed the size of the texture, scaled the x & y axis, minimized and scaled the bump, scaled the image, scaled the texture, and instead of it becoming smaller and thinner, it gives a completely different effect, it loses the lines, it becomes something else...
MikeJ posted Fri, 30 May 2003 at 10:31 AM
First thing I might suggest would be to lighten the texture a bit, as the picture of the stainless steel seems a few shades of gray lighter than what you have in your pitcher...closer to the the highlight on it. But after reading of your problem with stainless steel you posted last week, I spent several hours on Sunday trying to get a good stainless steel, and my closest efforts were about the same as yours. The silver material which comes with Vue seems to be almost there, but not quite...too shiny, too reflective, wrong highlights. Beats me! Maybe the makers of vue had a bad experience with stainless steel somewhere and ruled it out. ;)
tradivoro posted Fri, 30 May 2003 at 11:49 AM
Hi Mike, long time no see.. Thanks for your reply, basically, the reason that it gets dark is the bump, the bump darkens things up considerably... Even though the example picture is light, I was just using it to show the texture and the way light reflects off it... The one that i got on the teapot was the closest I got it... :) So yeah, maybe it's something that Vue is not up to... And maybe the makers of Vue did have that bad experience... :) sorry to hear that your efforts weren't rewarded, I thought maybe it was me alone... Maybe that should be next month's challenge, make a convincing brushed stainless steel - aluminum texture... :)
guitarzan posted Fri, 30 May 2003 at 9:57 PM
Kattleprod posted Sat, 31 May 2003 at 1:16 AM
kstar__2 posted Sat, 31 May 2003 at 3:57 AM
yup, quiterzan's looks almost like the real thing.
tradivoro posted Sat, 31 May 2003 at 8:29 AM
Wow, this is fantastic.. You guys did a great job... I knew somebody else out there could do a great job of this, thanks very much for doing this...
war2 posted Sun, 21 November 2004 at 12:43 PM
nice examples all three but yeah guitarzans is virtualy spot on, nice one.
