Karma opened this issue on May 30, 2003 ยท 3 posts
Karma posted Fri, 30 May 2003 at 6:58 PM
It's been a long time since I made thumbnails for the poser library and I can't seem to remember how! I know the image size needs to be 90x90 pixels, but how do I create the image in poser so when I resize it, the thumbnail doesn't turn out all distorted?
spectre3 posted Sat, 31 May 2003 at 1:24 AM
Set your document window size to some even number for width and height such as 400 X 400. You can then resize it without distortion. An even easier way is to set you document window size to 90 X 90 then render and save the image. Both work for me :) Spectre
ziggie posted Sat, 31 May 2003 at 4:37 AM
Sorry for butting in... and it may be obvious... but remember to save the rendered thumbnail image as png if you are using PPP. ziggie
"You don't have to be mad to use Poser... but it helps"
