Forum: Poser Technical
Subject: Changing Geometry figure, someone finding an error i can't reproduce.
Darkworld opened this issue on May 31, 2003 ยท 4 posts
Darkworld posted Sat, 31 May 2003 at 4:39 AM
I didn't know this was possible but apparently it must be. When a certain clothing figure's abdomen is selected, and you crank the Change Part dial to change the geometry, a tester is seeing it swap parts on a COMPLETELY different clothing figure instead?! Apparently like 50% of the time it changes the abdomen part of the figure you are selecting, and then the rest of the time it incorrectly is changing the shoulder part of a different figure... how is this possible, given the fact that they are 2 completely different changing CR2's? Thanks =)
FyreSpiryt posted Thu, 19 June 2003 at 5:37 AM
Crosstalk. It affects geometry swapping too. It's probably grabbing the first swapper that it finds with the same number.
Darkworld posted Thu, 19 June 2003 at 3:11 PM
Yes, I finally got it all figured out. Thanks!
FyreSpiryt posted Sat, 21 June 2003 at 7:02 PM
No problem! I'm glad that helped. That messed with me forever on a project until I discovered it was crosstalk.
