Subject: Poser imported background image
Karma opened this issue on Jun 01, 2003 ยท 5 posts
Karma posted Sun, 01 June 2003 at 3:56 PM
I imported a background image into poser 5 (a sky texture) didn't look right, but I had already made my scene. What I would like to know is how I get rid of that imported background image without restarting my scene.
Scathdebas posted Sun, 01 June 2003 at 3:59 PM
I think it is under edit, but there is a clear background image menu item.
Karma posted Sun, 01 June 2003 at 4:01 PM
Thanks a bunch!! :)
Little_Dragon posted Sun, 01 June 2003 at 4:03 PM
If you imported the image from the File menu, then: Display menu --> Clear Background Picture If you added the image from the Material Room by hooking up an image node to the Background, you'll have to disconnect it manually.
caulbox posted Mon, 02 June 2003 at 1:54 PM
Also, if you want to save your final image and still have the option of changing the background later... then save the image as a TIF file. Poser will generate an alpha channel which will allow you to replace the background (in your usual paint program) even after the image has been saved.
