Rayraz opened this issue on Jun 02, 2003 ยท 11 posts
Rayraz posted Mon, 02 June 2003 at 3:26 PM
(_/)
Rayraz posted Mon, 02 June 2003 at 3:27 PM
(_/)
woodhurst posted Mon, 02 June 2003 at 4:18 PM
that same thing has happened to me when i rendered alot of volumetric spheres next to each other--it maybe u could turn the fuzzy factor up or something? i dunno---good luck with this, cuz that explosion looks awesome!
ringbearer posted Mon, 02 June 2003 at 5:06 PM
Attached Link: http://www.3dcommune.com/3d/forum.mv?Bryce+read+8968082071#
Try this thread, maybe it will help.Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
RodsArt posted Mon, 02 June 2003 at 7:34 PM
Wow, that's an excellent tip.
___
Ockham's razor- It's that simple
catlin_mc posted Mon, 02 June 2003 at 10:41 PM
I had the same problem with volumeric textures on spheres when making this months challenge entry, where the spheres intersected the textures would vanish. Catlin
Rayraz posted Tue, 03 June 2003 at 1:09 AM
Thanx a lot for that link Ringbearer. I never even heard or thought of that trick. I'll check it out immediately. Someone says it also works on glass. This could be the best new trick I've learned in months!
(_/)
chohole posted Tue, 03 June 2003 at 2:42 AM
That is a great tip, thanks for the link.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Rayraz posted Tue, 03 June 2003 at 4:38 AM
Great tip. Does work with some things, but unfortunately it doesn't seem to work with these specific volumetrics. Maybe it doesn't work with true-volumes, but only with the old textures?
(_/)
Rayraz posted Tue, 03 June 2003 at 4:40 AM
I've got an idea to use a depth-render and a specially-made mask scene and fix it in PSP, but I don't know if it'll work. And I'll maybe need a render for every single particle.
(_/)
pakled posted Tue, 03 June 2003 at 12:23 PM
I've been known to use Symettrical (sp?) lattices, and texture them with volumes. Try Menno's Fire, it's a good flame mat, and standard Clouds mats for the smoke. I'd think you'd get a mixture of the 2 in a real explosion. Maybe playing with the transparency of the smoke will help. This question has come up before, and an explosion is a dynamic event; you can choose how far along the destruction sequence you want to go..
them boys blowed up real good..
-Redneck Rampage..;)
