GuardianAngel opened this issue on Jun 04, 2003 ยท 4 posts
GuardianAngel posted Wed, 04 June 2003 at 2:28 PM
can anyone best advise onto how to both save imported poses from renderosity. and to apply the imported poses to figures in poser 4?
Puntomaus posted Thu, 05 June 2003 at 3:19 AM
You have to put the poses into the Runtime:libraries:pose folder and apply the poses from there. Load your Poser figure, open the pose librarie, select the pose and apply it to your figure. When you like to save a pose, you click on the + sign at the bottom of the library folder, that adds it to your library.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
GuardianAngel posted Fri, 06 June 2003 at 12:44 PM
how do u download the imported poses straight to runtime: libraries: pose folder. directly from renderosity to the pose folder? do u select the folder to download to? i always download the imported items straight to winzip in order to unzip the imported items in question. how do i both unzip and send the poses to runtime:libraries: pose folder? please advise me best to do this. still having problems applying the imported poses to the poser4 figures. please e-mail me a.s.a.p. thanxs again. jason usher
Puntomaus posted Fri, 06 June 2003 at 1:20 PM
I always download files into a seperate download folder and run winzip from there, because I always scan downloads with my Norton Antivirus before I unzip them. If you download them into winzip this should be ok.
You can then:
a) unzip to a temporary folder and move the files manually into your pose folder or
b) unzip directly into Poser using the use folder path option in Winzip. But this will only work if the files are properly zipped using the right folder path, otherwise the files go elsewhere into your Poser directory.
I prefer to unzip into a temp folder and move them manually.
Hope this helps :-)
Friederike
Every
Assange
