Subject: Help with texture files please
DigitalDreamer opened this issue on Jun 06, 2003 ยท 4 posts
DigitalDreamer posted Fri, 06 June 2003 at 6:13 AM
I've just downloaded some texture files, for skin and leather, in jpg format. On opening Poser in Win Explorer, there are 2 texture folders.... one stand alone in runtime, the other a sub folder of libraries. Into which folder should I install the jpgs? Thanx DD
Staale posted Fri, 06 June 2003 at 7:15 AM
You can save them anywhere on your HD. If they belong to a model you have to store them in the folder the models texture info referees to.
Luthoricas posted Fri, 06 June 2003 at 7:58 AM
The "normal" location of Poser 3/4/ProPack's textures folder is in RuntimeTextures. Usually this is the folder you'd want the textures to go into. It sounds like the files you downloaded are just by themselves -? If there are no mat pose files along with them, then (if it were me) I'd create a subfolder in RuntimeTextures and put them there. But like Staale said, you can put them anywhere on your hard-drive if you want. Poser doesn't -require- you to have them in you RuntimeTextures folder.
DigitalDreamer posted Fri, 06 June 2003 at 8:02 AM
Thanks guys... most helpful
