Subject: Question about the Dedorkification Process
waffen opened this issue on Jun 16, 2000 ยท 4 posts
waffen posted Fri, 16 June 2000 at 5:14 AM
First of all: Hi guys! it's been a long time... Well we've talk about the dedorkification process, of the poser 4 male (and female) the last days, based on the research of Melanie (thanks!) But how can i make the same trik in bryce 4??? Is there any way to chage the Focal Lenght of the Bryce Cameras??? Poser has a great render engine, but i think that bryce has the best... Thanks in Advance Manuel.
LoboUK posted Fri, 16 June 2000 at 5:41 AM
Select the camera in Bryce (it's called "perspective") and click on the A in the little box. This brings up the attributes for the camera. At the bottom are 4 boxes - panH, panV, focal length, and zoom. The default focal length is (I think) 60, but you can change it here. Paul
waffen posted Fri, 16 June 2000 at 5:56 AM
Thanks Paul...! I'm going to do that I just couldn't think about rendering scapes in bryce and then put them on the background on poser!
PJF posted Fri, 16 June 2000 at 7:35 AM
You can also 'interactively' change the focal length / field of view by using the small button to the upper right of the main camera trackball. It is entitled 'Field of View'. It works in both 'Director' and 'Camera' views, but (logically enough) only changes made in camera view will be applied to the numerical setting in the attributes dialog for the camera.
