Subject: making my props animated?
grid opened this issue on Jun 11, 2003 ยท 3 posts
grid posted Wed, 11 June 2003 at 4:32 AM
Ok here is my Problem I Want to Make My Guns I made Into props For Poser Ok I know how To do this. The Thing i Want to Do Is have only a Few Iteams on the Weapon to Be animates. and I Would Like To Give The Strapes The cloth Feel. If Some one Could Help me where To look It Would be most Kind I have Tryed doing morph Targets But im inporting the File as object From Rhino then Trying to follow Body morphs tut Just dont seem to Go the Same way and I keep getting Errors.. I just Want a part of the gun to slide back and forth thanx for the help
Phantast posted Wed, 11 June 2003 at 4:51 AM
I've been trying to do something similar. Using morph targets doesn't seem to work. It's fine for things that bend, but when I tried using a morph target for part of a prop to rotate while another part slid, although the morph target loaded OK, in action all sorts of strange things happened. I think you need to make the prop into a figure, with the moving part parented. Then you use a phi file to restrict the movement of the parented element. Don't ask me how, I haven't worked that out yet.
SAMS3D posted Wed, 11 June 2003 at 7:37 AM
Yes, you need to make the prop a figure and if you don't want the parent piece to bend when you move the child you have to turn the BEND off. It properites of parent and uncheck bend. Sharen
