Forum: MarketPlace Showcase
Subject: SLAVE-ZERO - is coming - SF Ultraset series
kelc opened this issue on Jun 13, 2003 ยท 1 posts
kelc posted Fri, 13 June 2003 at 7:10 PM
Attached Link: SLAVE-ZERO ultimate SF
Slave-Zero is a Science Fiction themed product series for Poser , launching with four products (there will be more in the future ) . They can be used individually or combined into small and simple or huge and complex sets with many cambinations and variety.
So why start with four Products if they are ultimately ment to be used together ? Over 40 single intems , over 50MB of geometry and 40 Mb of high res texture maps is the simple answer. The picture you see below utilizes not nearly every item in the set and it uses only one of the two core platforms so far.
Though you can build huge sets all items are crafted with high detail for close shots and due to prescaled size and proportion ist easy to build new combinations quickly
Slave Zero is not exclusively for Poser. All the needed geometry is available in obj format and the Material-Map-Group naming follows a strict and simple logic - so setup is fairly easy.
Slave-zero is uncompromising and not made to fit a common taste , but If you are looking for something not quite ordinary then you maybe want to take a closer look
http://www.kafi.de/rr_products/slave_zero/gallery/page_01.htm
over 60 renders of Slave-zero are on this page - quite a few are up to 1600*1200 pix.
There will be a very sweet deal for a short time when the product arrives at the marketplace - so stay tuned
hope you enjoy the quick render
more coming soon
kelc
