begga opened this issue on Jun 16, 2003 ยท 5 posts
begga posted Mon, 16 June 2003 at 12:28 PM
I can't seem to remember what these props are called (dynamic props?) but when you load them: fx if it is a sword it goes to the figures hand. I have a sword that does that but I don't want it to go to the figures hand. Is the any way to like unparent it or what ever it's called. Unparent is probably the wrong word because it look like the sword is not parented. I did try to move it around but it's such a bug, it never moves the right way. Thanks Begga H
Adama posted Mon, 16 June 2003 at 12:47 PM
Attached Link: EVE & EVE
Greetings, I think you mean conforming figures...... Check out if the sword is in "Figures" or in "Props". If it is in "Props" you might have to conform it yourself to the hand. If it is in "figures" then check out if you done this: 1. you first load them into the workspace. 2. you click on "figure" - "conform figure" 3. a window appears where you can choose the figure you want to conform it to 4. click on the figure you want to conform it to Then it should do so. Greetings AdamaRHaseltine posted Mon, 16 June 2003 at 12:49 PM
Smart props. To unparent, Object>Set parent and select Universe. If the dials aren't workin as you expect, check that the rotations are zeroed in case you have gimbal lock.
begga posted Mon, 16 June 2003 at 12:55 PM
Thanks RHaseltine that is most likely it. And smart props is the word I was looking for :
Kendra posted Mon, 16 June 2003 at 10:12 PM
Please use the nudity flag when posting images that contain nudity. The banner may be subtle but it's still nudity and there are times when it may be inappropriate for someone to open an image containing nudity.
Thank you.
...... Kendra
