jas1746 opened this issue on Jun 20, 2003 ยท 6 posts
jas1746 posted Fri, 20 June 2003 at 6:29 AM
Hi, I am running a Windows XP system on a P4 2.0 Ghz processor with 1 gig of ram. I updated Poser 5 to SR3 and have upgraded Vickie 3, her head and body morps to SR1.1. My problem is that I have Victoria 3 and almost everything else installed into my older Poser 4 folders due to the fact that I also use Vue D'Esprit 4, which does not take too kindly to anything coming out of the Poser 5 folders. When I try to inject any morphs into Victoria 3 from in Poser 5 my PC does a great impression of the local village idiot. Simply put, the injection never takes place. It just constantly diplays the little watch icon. Now injection of morps seem to do fine in Poser 4, I have not tried a full body or head morph yet, but Poser 5 was locking up on even the smaller level morphs. Is there a fix for this, or do I simply have to install Victoria 3 into both Poser 4 and 5? TIA, JAS
jas1746 posted Fri, 20 June 2003 at 8:30 AM
I actually found a way around the issue after psoting this message. I have e-mail DAZ and asked if there is a fix for this as well. What I do is open the Poser 5 scene in Poser 4. It tells you it is a newer file and a pop-up comes up telling you that it can't locate a resource file. Just tell it ok. The scene opens then. I loaded V3 into the scene, injected all of her morphs which only took seconds. Save the scene, then reopened it in Poser 5. It is something of pain, but at least I found a way to make it work. JAS
Puntomaus posted Fri, 20 June 2003 at 9:07 AM
Put a copy of the !DAZ folder (under Runtime:libraries) into your P5 runtime directory and the morph injection works fine. That is all you have to do, no need to inject all the morphs in P4.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
jas1746 posted Fri, 20 June 2003 at 9:09 AM
Thanks Puntomaus! I'll try that! JAS
jas1746 posted Fri, 20 June 2003 at 3:35 PM
Bingo, That Works! Thanks again Puntomaus! JAS
Puntomaus posted Fri, 20 June 2003 at 4:24 PM
Your welcome :-)
Every
Assange
