samcopcutt opened this issue on Jun 20, 2003 ยท 8 posts
samcopcutt posted Fri, 20 June 2003 at 7:05 PM
I've lost my window on the pose page.
abg24 posted Fri, 20 June 2003 at 10:37 PM
Double click the "UNTITLED." This sould open up the display window. If not then from the File bar, select File -> New. From there you should get a promt "Do you wish to save changes to 'Untitled.pz3.' Select "Don't save" and wait. You will see a new display window after a few seconds.
samcopcutt posted Sat, 21 June 2003 at 6:50 AM
my "untitled" had gone too, i downloaded the sr3 lastnight and loaded that now i have a window in the pose room but the window in the other rooms have gone.
abg24 posted Sat, 21 June 2003 at 5:03 PM
Sorry to keep you waiting. Okay, fire up Poser. From the File Menu select Window, at the bottom of the drop down menu select Window Size. At the dailogue look at the Width and Height, if there are no numbers then type in 200 x 200. Make sure that the boxes next to Constrain Aspect Ratio and Lock Window are unchecked. Click, Okay.
samcopcutt posted Sat, 21 June 2003 at 5:22 PM
still missing, thanks for your help:)
abg24 posted Sat, 21 June 2003 at 5:37 PM
Okay, Form the File Menu click Edit and from the drop down Menu select General Prefrences. In the dialogue, under Document Preference select Launce to Factory State and under Interface Preference select Launch to Factory State. Click the button Set Prefered State. Keep your cursor over the dialogue box. Once your working icon returns to the cursor, click the Okay button at the bottom of the dialogue and shut down Poser and then fire it back up.
samcopcutt posted Sat, 21 June 2003 at 5:51 PM
we have all windows back,thank-you,thank-you,thank-you:)
abg24 posted Sat, 21 June 2003 at 5:52 PM
Happy Render'n.
