Vandaler opened this issue on Jun 21, 2003 ยท 4 posts
Vandaler posted Sat, 21 June 2003 at 4:24 PM
I'm sure someone can help me with this. I want to easely create rocks and trees for export in another program. However, when I select either the tree or rock and go "File/Export"... the export feature is greyed out. Am I missing something? does it have anything to do with procedural textures? Thanks for your guidance.
antevark posted Sat, 21 June 2003 at 4:38 PM
You can't export trees in Bryce. but you should be able to export rocks. I think adding a procedural texture would have something to dp with not being able to export the rocks. Make some more rocks, but don't add any material, because you wouldn't be able to export the material anyway.
Vandaler posted Sat, 21 June 2003 at 4:39 PM
Thanks!
ringbearer posted Sat, 21 June 2003 at 4:46 PM
Attached Link: http://www.bantam3d.com/
You might need to click on the "e", which brings up the smoothing window, then ctrl-D, which will give you an export dialog. Or you can use Bantam 3D grass-it makes rocks and it's free. ArleenThere are a lot of things worse than dying, being afraid all the time would be one.
