Forum: Photoshop
Subject: drawing along the path
aleks opened this issue on Jun 25, 2003 ยท 8 posts
aleks posted Wed, 25 June 2003 at 3:54 AM
i made a simple figure with paths and now i want to draw it's contour with a pen but i'm unable to click that button underneath the path palette, it's not selectable. what's wrong? i made it on p7 (pc), tried it on p6 (mac) with the same result. am i missing something important? thanks!
kd_kedar posted Wed, 25 June 2003 at 5:40 AM
complete the path & make selection, then go to edit stroke give the desired value in unit or in 'mm', 'cm' (in PS 7 only). & here'z the counter
aleks posted Wed, 25 June 2003 at 6:28 AM
what do you mean by "complete the path"? does it have to be closed?
dreamer101 posted Wed, 25 June 2003 at 6:52 AM
The path does not have to be closed. Do your path then click on "stoke path with brush" at bottom of Path palette. The stroke will be your foreground color and the stroke size will be the size you have your brush at.
aleks posted Wed, 25 June 2003 at 7:05 AM
yes, i have a path already, it is only that the "stroke path" isn't clickable, there's that no-parking sign when i go over it with the mouse.
dreamer101 posted Wed, 25 June 2003 at 7:31 AM
You sure it's a path and not a shape layer (filled)?
aleks posted Wed, 25 June 2003 at 7:45 AM
goddammit you are right! it's a filled shape layer... is there a way to convert it back to path?
dreamer101 posted Wed, 25 June 2003 at 8:16 AM
If you just need it stroked, you can right click on layer and rasterize, Ctrl-Click layer (to select it) then Edit - Stroke.
