Subject: Camera sync (bryce to poser)
amboni opened this issue on Jun 22, 2000 ยท 3 posts
amboni posted Thu, 22 June 2000 at 8:52 AM
Is there a way to synconize the movements of the camera between bryce and poser?
LoboUK posted Thu, 22 June 2000 at 8:59 AM
I'm not 100% certain what you mean by this. Camera information from Poser isn't carried over into Bryce. If you mean having the camera set at the same "focal length" and 3D co-ordinates, you can approximate this. Select the camera ("perspective" in Bryce) and click on the little "A". You can then set up the focal length exactly as it is in Poser. As to moving and positioning the camera in Bryce so it matches Poser, that's pretty much guess-work - there isn't a way to actually synchronise position, rotation, or movement between the two apps. Paul
Viomar posted Thu, 22 June 2000 at 6:05 PM
Actually! There's the "Old Graphist" Trick... In Poser Activate the Perspective Guide(Not sure of the exact name), Since those guides wont show in a rendered image; Quickly set up some boxe primitives aligned with vanishing lines. That way you can import your image in bryce as reference... Hope this is clear enough for you! Wish i could show you, but i don't have bryce. :-( Marc
