brandonc opened this issue on Jun 27, 2003 ยท 3 posts
brandonc posted Fri, 27 June 2003 at 6:42 PM
ok so i did this tut http://www.3dtoday.com/Tutorials/2001/Sept/Pmorphsinc/default.asp but i did a box then i used the points to make part of the box come out but what i want to do is make a morph for a "bulge" comming out of the wall but if i use 2 objects it doesnt work anyone know why?? thanks
compiler posted Sat, 28 June 2003 at 4:16 PM
What you have to do is 1-import the "flat wall.obj" 2-menu > object > load morph target 3-in the "find file" box, choose the "bulged wall.obj" 4-give a name to your morph (eg : "bulge") 5-in the parameter palette, turn the "bulge" dial from 0 to 1. The bulge should appear. If it doesn't work, please tell us where and how it failed so that you can give advice. Hope this helps. Compiler
lesbentley posted Sat, 28 June 2003 at 9:38 PM
