Forum: MarketPlace Showcase
Subject: Introducing Darsha for V3!
Morris opened this issue on Jun 30, 2003 ยท 17 posts
Morris posted Mon, 30 June 2003 at 12:54 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=20773
Meet Darsha. ( Sanskrit- meaning to see to have vision ), an exotic beauty for Victoria 3 by Morris and Stacey_73! A high resolution striking skin texture inspired by the beauty of India, including a traditional Henna body texture by Stacey!
Created from hi-res digital photos to give you incredible detail and realism, a must have to add to your Vicky 3 library!
You MUST own Victoria 3 Base and both the head and body morph packages to properly use this package. These items can be purchased through DAZ3d.com
The MOR poses will inject the correct Morph targets and set the values to set up your Darsha character. However, in order to utilize the expressions for Darsha, you will need to use the injection pose located in the following directory, Poses/!V3 Expressions INJ.
To install this package simply locate your Poser 4 folder and unzip, the files are already set to create and load into the proper folders.
In this package you will find:
1 Mor pose that will inject all required morphs and create the Darsha character
1 Mat poses to apply the default Darsha textures
10 Mat poses to apply the extra Make-up, change of eye colors & body textures
1 Default Body texture map (3000x4000)
1 Henna Body texture map (3000x4000)
1 Jeweled Body texture map (3000x4000)
4 Head texture maps for Darsha (4000x2719)
1 Teeth texture map (900x900)
6 Eye texture maps (500x500)
1 Transparency map for the eyelashes
11 full body poses
11 light settings designed to bring out Darsha's skin tone and set up to render beautiful with crisp shadows
