Philywebrider opened this issue on Jul 01, 2003 ยท 9 posts
Philywebrider posted Tue, 01 July 2003 at 4:27 AM
I have Poser4 with Propack, and the 4.03 fix. I loaded V3, added head and body morphs, added Daz skin texture, added Koz alice hair and saved as .pz3. I save often so not to lose my work. No problems until I open the file again. The file opens, but there is no V3 Figure, the file name is there, but the screen says "no figure" I can't figure, "no figure", go figure.
spurlock5 posted Tue, 01 July 2003 at 6:38 AM
Could be a lot of things. The first thing is to check to see if the "hide figure" option is checked. The hot key for this is Control+H. Get the figure dropdown panel on the main menu and check show all figures. Another possibility is that the figure has been moved off camera. Try different cameras. Using top camera and zooming out is a good way to find it. It is there, it is just a matter of finding it.
smiller1 posted Tue, 01 July 2003 at 7:18 AM
I've no idea but I just wanted to say that you should've called this post 'figure it out' :0)
Philywebrider posted Tue, 01 July 2003 at 10:03 AM
The poser window actually says "no figure" I tried the different camara angles (on the left side of the window), no luck. I closed and restarted...same problem. I tried saving 3 to 4 times after recreating the figure. I tried Fully clothed Nude with hair Different Hair "Hide Figure & Show all figures" are not active on the pull down window, (they are Greyed out).
RHaseltine posted Tue, 01 July 2003 at 12:51 PM
What do you see in Window>Hierarchy editor? Just the ground plane, or your figure? How big is the PZ3 file? If you open it in a text editor and search for :Runtime:Geometries do any lines come up, and if they do do which OBJ files are referring to?
spurlock5 posted Tue, 01 July 2003 at 3:13 PM
You are using the injection head and body morphs. Are you selectively entering them or loading all of them at the same time. If Poser goes to load a file and there is not enough memory to load all of the figures, it might not load one it could not handle. The Victoria 3 is pretty large. With all of the morphs loaded, it would be larger still. How much memory do you have? I am using 512 megabytes and it is slow loading for Victoria 3. Also, make sure that you don't have any dynamic hair or clothing which doesn't sound like you have. Frankly, I am stumped.
Philywebrider posted Tue, 01 July 2003 at 5:33 PM
I have to redo the figure again, I deleted it. It was about 133 Mb. Text editor is a little beyound me right now. I loaded all head and body morphs. (I have 1.5 gig of memory). (all memory settings in Poser are default)It was just one figure, one gown, no dynamic hair or clothing. Yep it is still slow loading/saving. It goes through the cycle of loading, I just lose the figure (the empty window does have the name it was saved under). I noticed my Pose library is 200 files. I know you can have 250 files, but I'll try reducing the number some more, (I reduced the quanity earlier) I'm just grabbing at straws.
smiller1 posted Wed, 02 July 2003 at 3:49 AM
Clutching at straws! I'll say, I can't see where you make the connection. I think you are going to have to approach this logically. Go through your steps saving each step as you go as a different file, for example.... Step1 Loaded V3.pz3 Step2 Added head morphs.pz3 Step3 Added body morphs.pz3 etc. Then try reloading each file to find when the problem occurs. When you get to the step that causes the problem, go back to step 1 and apply the action that caused the problem. Close the file (and poser to be sure) and then reload the file. If it fails, and hopefully it will, you've isolated the problem and can then attempt to solve it. If it succeeds then you are either facing a resource problem or the problem is caused by a combination of steps- you'll then have to figure out which of the other steps in conjunction with the one you've identified causes the problem.
Philywebrider posted Wed, 02 July 2003 at 4:14 AM
smill1 I give it a try.
