3dtiger opened this issue on Jul 04, 2003 ยท 9 posts
3dtiger posted Fri, 04 July 2003 at 11:23 AM
hi does anybody know where i can find tuts to make prop objects in 3ds max 5 to use in poser 4?
TrekkieGrrrl posted Fri, 04 July 2003 at 11:35 AM
What kind of props? Things like doors or more complicated stuff? It's not hard, if you know how to model, but the approach depends on WHAT you're making :o)
3dtiger posted Fri, 04 July 2003 at 12:12 PM
well i was thinking on a Nunchaku for my Bruce lee character
TrekkieGrrrl posted Fri, 04 July 2003 at 12:34 PM
Ah :o) That is probably pretty easy to make. Make the nunchaku in a way so that you do not bend the chain, then divide the chain into smaller parts and make the handles and all the chain links each a group. Then get PhiBuilder (Look at the link at the right in the Webring Top 15, Roy's Poser MAX Tutorials) and use that to make a poser hierachy. That's more or less it. It may need some joint ajustment, which you can do inside Poser afterwards.
Hanz posted Fri, 04 July 2003 at 12:53 PM
Trekkie, I have always wondered (well, if not always, then at least at some time or another) what modelling prog do you use for your props and stuff? Max 5? Or...? I'd just like to know... :) -Hanz
TrekkieGrrrl posted Fri, 04 July 2003 at 1:45 PM
I've sent you an IM :o)
3dtiger posted Fri, 04 July 2003 at 4:05 PM
thank you for the help
brandonc posted Fri, 04 July 2003 at 7:46 PM
a im ?? we all want to know ;)
TrekkieGrrrl posted Sat, 05 July 2003 at 5:23 AM
No big secret L Just easier to make long explanations and so on in danish ;o) I'm using Max 3.5 and a little bit of Lightwave :o)
