doc69 opened this issue on Jul 04, 2003 ยท 5 posts
doc69 posted Fri, 04 July 2003 at 3:28 PM
Those stars are a beautiful product, I think.... looks very fine and everything works but NOT the shapes, rendering I get some sort of waffles and when I shift to another shape it just stays the same. So, just waffles in the background and some faint stars in the foreground but no sign of bubbles or any other shapes....
compiler posted Fri, 04 July 2003 at 3:57 PM
Are you using Poser 5 ? If so, have you try disabling the "smooth polygons" option for these figures ?
doc69 posted Sat, 05 July 2003 at 2:10 PM
Poser 5 is the system I tried diabling smooth polygons, no result, maybe faulty obj.. (problem is that the form does not apply),maybe it is not suited for Poser 5, I keep only seeing the XYZ planes. Don't bother, anyway, thanks for the help. fine forum!!!
RHaseltine posted Sat, 05 July 2003 at 2:48 PM
Sounds like the transparency is not applying. I'm not familiar with Poser 5, check your documentation on how to apply transparency maps and then the textures in Runtime/Textures/Majik are all transmaps for the intersecting planes except for the two with "hair" in the name.
raven posted Mon, 07 July 2003 at 1:33 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1282702
This thread should sort you out :)
