Forum: Poser Technical
Subject: Poser File(cr2,pz2) <-> CSV File
kim99 opened this issue on Jul 06, 2003 ยท 3 posts
kim99 posted Sun, 06 July 2003 at 4:56 AM
Attached Link: http://www.globetown.net/%7Ekim99/tool/CR2Builder/02h/indexe.html
Hellow.
New Functions of CR2Builder02h11.
*LeftTV -> Left Side TreeView.
*Sorry Mac Users. PC Windows Only.
the function to convert From Poser File to CSV File.
  1. Make a Test Poser File.
    0-0.Lunch Explorer.
    0-1.Change File Holder (Directory) to "Runtime:libraries:Pose:Zygote's Victoria"
    0-2.copy "beach pose 1.pz2"
    0-3.rename "bp1.pz2"
  2. lunch CR2Builder02h.exe. ( O2h11 or later )
  3. Open a Poser File named as "bp1.pz2" on LeftTV.
    [LeftTV]-[Open]
    Select "bp1.pz2" on Open Dialog.
  4. Save CSV File named as "bp1co.csv"
    [LeftTV]-[Save As (CSV Child Only)]
    rename "bp1co.csv"
  5. Save CSV File named as "bp1.csv"
    [LeftTV]-[Save As (CSV)]
    rename "bp1.csv"
the function to Change Poser File from CSV File.
  1. Edit a file named as "bp1co.csv" used by Text Editor or Excel.
    *If you use Excel, Sheet Close. because Edit File is locked by Excel.
  2. Lunch CR2Builder02h.exe ( 02h11 or later )
  3. Open a Poser File named as "bp1a.pz2"
    [LeftTV]-[Open] or [LeftTV]-[Open Files]
    select "bp1a.pz2" on File Open Dialog.
  4. Open a CSV File named as "bp1co.csv"
    [LeftTV]-[Open]
    select "bp1co.csv"
  5. Check the changing on LeftTV.
the function to scrach Poser File from CSV File.
  1. Edit afile named as "bp1.csv" used by Text Editor or Excel.
    *Must not delete line (row).
    *If you use Excel, then Close Sheet. because Edit File is locked by Excel.
  2. Lunch CR2Builder02h.exe.
( 2. Clear LeftTV
[LeftTV]-[Clear] )
  1. Open CSV File named as "bp1.csv".
    [LeftTV]-[Open]
    Select "bp1.csv" on File Open Dialog.
  2. Look LeftTV, you will see a Tree Structure.
Other functions
Drag and drop From some TreeNodes on LeftTV to Buffer Page.
Bug Fix: When Push DEL Key, Delete some TreeNodes selected On LeftTV.
If you have any questions or any ideas.
Please teach me for child english or japanese language.
mailto:kim99@geocities.co.jp
Thank you.
doozy posted Sun, 06 July 2003 at 3:38 PM
  1. lunch CR2Builder02h.exe. ( O2h11 or later ) <<< "lunch" eh? Is that a clue about how long it takes?
_dodger posted Mon, 14 July 2003 at 2:22 PM
I have a question: Why? I can see why someone would want to convert a Poser document into XML, but why the hell wold you want one as a CSV? I don't recommend Excel as the CR2 editor of choice, you know...
