ockham opened this issue on Jul 06, 2003 ยท 9 posts
ockham posted Sun, 06 July 2003 at 6:36 PM
Attached Link: http://ockhamsbungalow.com/Python/ZoomToExtent.zip
This was suggested by Maclean a few days ago. If your camera has drifted way out of range, or you suspect an object is somewhere in the scene but not findable, you can just click on this ZoomToExtent script. The currently selected camera will zoom out or in, and slide left or right, until its view field includes all the "solid" objects in the scene. (By "solid" I exclude GROUND, lights, cameras, etc.) This is a first draft; it works only on Main and Aux cameras, and works fairly well but not perfectly. See the readme for more detail.ford3auss posted Sun, 06 July 2003 at 8:24 PM
Does this work with P5, thanks for your time...
ockham posted Sun, 06 July 2003 at 11:12 PM
Yes, it does work in P5 / SR3, which seems to be the "killing ground" for Python scripts. Just tried it. I'm hoping that somebody who has a "feel" for cameras will put this through its paces and suggest improvements.
jjsemp posted Sun, 06 July 2003 at 11:51 PM
Ockham, You are a poser hero. -jjsemp
Connatic posted Mon, 07 July 2003 at 12:16 PM
Thanks Ockham! I use your scripts regularly. I will give this a try and send feedback. Is it possible to make a script to delete selected textures from the list? I often have dozens of textures that I have decided to not use, but still have to scroll through them. Any tool to help manage the textures would be a big help.
ronstuff posted Mon, 07 July 2003 at 2:35 PM
Thanks, ockham - your scripts are really the best!
TrekkieGrrrl posted Tue, 08 July 2003 at 7:01 AM
Ockham, I must start by saying that I haven't yet tried your script, but I have read the readme :o) Assuming this script doesn't allready do so: Is it possible to make a "zoom to..." or "find..." script? As when you've loaded something apparently offscreen and then have the camera zoom to the selected object?
ockham posted Tue, 08 July 2003 at 5:37 PM
Attached Link: http://ockhamsbungalow.com/Python/FindThis.zip
Yes.ronstuff posted Tue, 08 July 2003 at 6:11 PM
Ockham, you are just too much for words! It is hard to find a way to say "Thanks" enough. Now could you possibly fix Poser 5 for me :-O
