Forum: Bryce
Subject: Can you export image at higher resolution that 72dpi.
lilmikee opened this issue on Jun 26, 2000 ยท 4 posts
lilmikee posted Mon, 26 June 2000 at 5:58 PM
I have been having a hell of a time trying to save my renders at a higher resolution than 72 dpi for printout purposes. Currently I have been rendering the image at twice the size and doubling the resolution to 150 dpi and cutting the size of the image in half. Is there another way to export teh image at a higher resolution in bryce4?
Ghostofmacbeth posted Mon, 26 June 2000 at 10:24 PM
There is a weird little thing someplace, under file I think, called render to disk. It willllow you to specify the resolution as higher. Though it doesn't report render time...
lilmikee posted Tue, 27 June 2000 at 6:26 AM
Thank you Ghost, that is correct it is render to disk. I found a similar question on the message board and that was teh sollution. I tries it and it worked fine.
Spanfarkle posted Tue, 27 June 2000 at 9:53 AM
You can have Bryce report the render time by checking it in the pull down when you render to disk.
