Subject: Have You Seen A Clown Collar???? Etc.......
Strixowl opened this issue on Jul 10, 2003 ยท 12 posts
Strixowl posted Thu, 10 July 2003 at 8:14 PM
The pleated or rufflee large round type. I'm also looking for anything Clown.....props etc. For Vic3 or adaptable to her. Already have FrankenClown. Thanks All, Strixowl
TalleyJC posted Thu, 10 July 2003 at 9:26 PM
If you post a Pic, I may be able to model one for you in Lightwave and export a .obj...
Strixowl posted Thu, 10 July 2003 at 9:32 PM
Cool. I'll see what I can find :-)
cooler posted Thu, 10 July 2003 at 9:59 PM
Strixowl, I have one for V2 as part of my jester (jesterette?) outfit in freestuff at 3D Commune
TalleyJC posted Thu, 10 July 2003 at 10:43 PM
Hey Strixowl....
This was real fast but like this?
xoconostle posted Fri, 11 July 2003 at 12:34 AM
Attached Link: http://www.creepyclown.com/creepydownloads.htm
You can easily isolate the collar.
RawArt posted Fri, 11 July 2003 at 6:19 AM
I have one of those collars I downloaded, but for the life of me I cannot fine the readme for it. It is in a folder called "LM Props"...perhaps someone can shed more light on this
Strixowl posted Fri, 11 July 2003 at 10:14 AM
Wow!! Thanks for all the help from everybody. TalleyJC-that was quick and looks really good.
TalleyJC posted Fri, 11 July 2003 at 12:34 PM
Do you want me to continue on it? Do you want it to fit Michael or Victoria? More wrinkles? smaller? larger? Should it stick out or drape on the shoulders?
Strixowl posted Fri, 11 July 2003 at 7:37 PM
TalleyJC-Sure if it's not any problem. It's for Victoria3. As for wrinkles it looks great as is and it should stick out. NOT drape. End result I'm after will be 3 of these layered with the ~~~~~~~~~~~ wrinkles of each layer lineing up with the layer above and/or below to make a 3layered collar.
TalleyJC posted Sat, 12 July 2003 at 12:12 AM
You may need to play with the UV map.... The UV I created in Lightwave didn't export so I did a quick Y axis, planar map in UVMapper.... I also have a silly texture I did for it as well as the Lightwacve UV map template that you should be able to use..... Give me an address I can email the zip file.... its 1.1meg.... don't worry the model is only 62k.... I added the texture maps to the zip
TalleyJC posted Sat, 12 July 2003 at 12:16 AM
Its still rough but I an tweak it as you need.
