eefx opened this issue on Jul 14, 2003 ยท 7 posts
eefx posted Mon, 14 July 2003 at 4:29 PM
Can I create a wire frame or partial wire meshed into a skin texture render in Carrara 2?
Harpazo2003 posted Mon, 14 July 2003 at 4:37 PM
You will have to render the image in both wireframe mode and regular render then do a composite is a paint program. Ive never done it but it should be as easy as laying one that is transparent blend, on top of the other. Kevin
eefx posted Mon, 14 July 2003 at 4:44 PM
But I can render a wireframe image?
Nicholas86 posted Mon, 14 July 2003 at 5:47 PM
Yes. You could also use a wireframe texture on an object and do it that way. To render as wireframe, just change the render type to ZBuffer, make sure render mode is wireframe. And then choose either fast lighting or actual lighting. Brian
cckens posted Mon, 14 July 2003 at 5:50 PM
Sure, why not? Under the render room there is a setting for ZBuffer. Select this as your render mode and hit the wireframe button and you should be set. Now understand... if your models are shaded they will take on the color of your color shader, so if you are looking for a pure white wireframe you will have to find a way to use only a white shader or the default. I'd suggest creating a second .car file and removing all but the default shader. This way you don't lose the original. Ken
eefx posted Mon, 14 July 2003 at 5:52 PM
thank you everybody
trogboy posted Mon, 14 July 2003 at 9:29 PM
get 3D Studio max problem solved :D [IMG]http://market.renderosity.com/~carrara/emoticons/dork.gif[/IMG]
