Seco_xxx opened this issue on Jul 15, 2003 ยท 4 posts
Seco_xxx posted Tue, 15 July 2003 at 3:21 PM
Does anyone know if i can make things in cinem4d to use as props in poser? and if so how do do this.
Little_Dragon posted Tue, 15 July 2003 at 3:58 PM
Export your mesh from Cinema 4D in .obj format, then import that into Poser. From there, you can scale it to the proper size, make material adjustments, and save it to the Prop Library.
peejay posted Tue, 15 July 2003 at 5:34 PM
Remember the different file formats are treated differently in Poser. If you want soft rounded edges use .obj, if you want hard and mechanical, import to Poser from .dxf
brandonc posted Tue, 15 July 2003 at 8:25 PM
or u can open the .obj in uvmapper and split verticals to get a hard edge
