Subject: Hair Style with problems
3Dream opened this issue on Jul 16, 2003 ยท 3 posts
3Dream posted Wed, 16 July 2003 at 8:52 AM
Hello
I am working on a 3D object in RHINOceros (Rhino). Its the base for my next free hair style. But I have a problem,
I have created first a half part of the object with a Surface, then I converted Surface to a 3Ds model. After that I made a mirror option so I get my object complete.
But, as you can see at the image 1, there is a very visible line at the middle that needs to be smoothed. As you can see on image 2, the 3D object are in reality two, so I slected both and I have join them (image 3).
After that, I selected the points to smooth but they separe in two points. The question is, how do I convert 2 points in 1 only point? Or, do I have to use other program to do this?
Thank you very much for your attention. 3Dream.
STOREhttps://www.renderosity.com/marketplace/vendors/3Dream
FREEBIEShttps://www.renderosity.com/users/3Dream/freestuff
MysticMind posted Wed, 16 July 2003 at 9:39 AM
One thing that you can try is to import the file into Poser and select the "Weld Identical Vertices" (or something along that line) option from the import dialog when you do. That might help fix it.
thgeisel posted Wed, 16 July 2003 at 9:50 AM
Attached Link: http://www.poserpros.com
only help i can give you: at poserpros is a very good and populated rhinoforum and most of the people modell for poser.
