Subject: poser animation file
earldancer opened this issue on Jul 18, 2003 ยท 2 posts
earldancer posted Fri, 18 July 2003 at 11:34 AM
Attached Link: http://www.earldancer.com
If I make a dance animation, what would I have to do to load it into poser Poses' to use with other models. Appreciate any help. Earldancer
Little_Dragon posted Fri, 18 July 2003 at 7:23 PM
Select the figure, open your Library, browse to a Pose folder, and click the "+" button at the bottom of the Library palette. Poser will eventually ask if you want to save the pose as a single frame or a multi-frame animation, and if the latter, how many frames. If you've saved the animated pose properly, you'll see a number in the upper right-hand corner of its Library thumbnail, which represents the frame count.
