Forum: Bryce
Subject: Animated underwater caustics
Hepcatbrandon opened this issue on Jul 18, 2003 ยท 7 posts
Hepcatbrandon posted Fri, 18 July 2003 at 11:45 PM
In fooling around in the DTE I found a fairly nice way of simulating UW caustics using procedural textures: Here I used Voronai DistSq1 noise set to 3D and scaled to about 30 in all directions. Make the top color bead black, middle grey, bottom white and stick the texture on a light. you can animate the frequency in one of the directions or experiment with animating phase. just a quick render, I think with some fiddling the effect could be more convincing
Zhann posted Sat, 19 July 2003 at 12:52 AM
Uh, tutorial with pics? I think I follow but I'm not sure...
Bryce Forum Coordinator....
danamo posted Sat, 19 July 2003 at 1:15 AM
Cool! Nice to see a "native Bryce" solution to a question I had not long ago! The effect looks great in this pic!
Ornlu posted Sat, 19 July 2003 at 2:08 AM
Also, you could take 2-4 spotlights, give them these as gel maps, place them over the image and put each on a circular track, then you just loop the spotlights (pointing down) each moving randomly around a different track, creates extremely realistic movement, especially if you mess with their accelerations in the AML.
brholte posted Sat, 19 July 2003 at 7:50 AM
excellent!!! No more searching the web for caustic gels.
catlin_mc posted Sat, 19 July 2003 at 9:14 AM
Looks very realistic and sounds so simple, but I'm with Zhann, ie. unsure. Catlin
Hepcatbrandon posted Sat, 19 July 2003 at 1:13 PM
Here's a screen capture. first create a light, in its edit window put a dot by Use Gel, click procedural, in the mat lab put a bead in the diffuse column then in the dte use the above settings. hope that helps. you could also try the texture as 2D instead of 3D I think you get fewer "clumps"
